With that much stringing and blobbing I would think you could get away with dropping the temp by 10 degrees which should help with overhangs...
gr5
Thanks for the advice, I will find time to read through the article, It's a big help to me,
I was wondering if there is a graph that explains settings of Cura, so one can understand it visually.
Nick Foley
Thanks for the idea, I will try to set the temp to 200 and give it a shoot.
after I lowered the temp to 200, the strings on the upper part of the print appeared to be less than the previous one
gr5 1,967
For your worst surface - it is almost horizontal - I can't get any better than this. The most important thing is lots of fan but I suspect you already have your fans on at 100%. Print speed won't make a difference unless you go to 5mm/sec with .8mm shell because when it does the second inner pass it fixes the outer edge (remelts it). But any faster than 5mm and it is no help. There is more information about this here (note that the first few theories were wrong but we eventually figured it out):
http://umforum.ultimaker.com/index.php?/topic/4094-raised-edges/
Hopefully someone on this forum will become an expert at second extruder support materials and we can some day print this part perfectly.
Or just try 5mm/sec. I dont have the patience to print that slow.
