Posted · Moving too fast
Hi
I recently got my Ultimaker and have made some decent prints using ReplicatorG and SLickr
I switched to NetFabb but after creating the toolpath and loading the Gcode in Replicator G i get a lot of:
You're moving too fast! G1 X103.2600 Y104.4100 Z18.0800 F9720.0000 E238412.0313 turns at least one axis faster than it's max speed.
and that is for everything i try, also the calibration gcode
i did set the M92 E14 in the start code. in the machine settings (general settings) also max XY and Max Z accell is defined (7.0 and 10.0 resp)
i do not know whether these are correct or what they should be. should i import some machine settings from somewhere first?
cheers
Bas
    The settings in repG are set at 150mm/s maximum feedrate. You can safely ignore it (by adjusting the ultimaker.xml file in the folder machines) but notice that at really high speeds, marlin will kick in.
