Thanks!
I ended up just sticking a piece of PLA in between so the limit switch would trigger earlier.
Does this offset the dimensions of the build area though? (Not that I would print all the way out to the edge anyways)
How would the printer know when it hits the opposite edge? I don't see any limit switches for that side. Is that software based in the printer settings of how big the build area is?
gr5 1,872
Yes, bend back the fan. Also after bending it back listen for the limit switch and make sure when it clicks there is still a gap between the fan and the wall. If not the limit switch may have moved or it may be broken. If the limit switch is broken it is obvious because homing the X axis would be incredibly loud. It does the "death rattle" when the limit switch isn't working.
Still the switch may have moved and you might want to bend it back by .5mm or so after you bend the fan duct back.
