Goed bezig Bas!
Nice Research!
Interesting report. In my year-long experience with a TrinityLabs hobbed wheel, it did occasionally clog as a result of some other issue, but when it didn't unclog on its own, it was quite easy to clean out (assuming easy access).
I've just started using a MK8 hobbed wheel on my UM2, and so far it seems to get a better grip on the filament with fewer skips than the original knurled wheel. Having smaller effective diameter, it should give a bit better extrusion resolution - I'm still calibrating, but using e-steps around 340 for now.
Awesome Bas. In my tests:
http://umforum.ultimaker.com/index.php?/topic/4222-pulling-force-of-um-extruder/?p=34887
The UM2 feeder motor slips somewhere around 4.5 to 5.7kg or (multiplying by 9.81 m/s/s) 44 to 56 Newtons when using the default current (I believe 1.25A limited) although the motor can exert more force when spinning faster before the current limiting feature allows it to slip back.
IRobertI 473
Thanks Bas, it's great that you guys are so open with this stuff.
