Ooze shield at single head prints - strange...
drayson
Posted · Ooze shield at single head prints - strange...
Today I tried to use the ooze shiled function in cura for a single-head print.
Cura does it but strangely follows the whole contour of the part - means not just applying a straigt contour around at max perimeter, no, it really applies something like a "skin"...
Has anybody tried this before? Experience?
Or is it a bug???
without ooze shield feature
part1
with ooze shield feature
part3
part2
    Have not tried it with a single print yet.
    but with dual extruder it creates a skin or cocon indeed, with a vase, even top en inside...
    The oozeshield itself helps... hard to watch what is happening though.
    Unpacking is half the fun;)
    WP 000819
    I think the ooze shield is very close to the object (2mm). I had a case where ooze shield and object were kind of merged and the object was partially destroyed. Thus, I extended the distance in the CuraEngine to 5mm and will check if it helps.
    Another issue I had with the very close ooze shield is insufficient cooling of the object.
    However, I have the ooze shield activated all the time, even for single extrusion prints but with them it is never printed. I wonder how you drayson managed to have the ooze shield with a single extrusion print. Have you acitvated some support on the second extruder?
    Nope, but I was also astonished, but I think found it out...
    my setup: Cura 14.07
    - checked the oozing-box
    - support is on first extruder and everywhere
    - bed adhesion is brim.
    - second extruder is not used.
    In layer view it is applied and acc. to my gcode simu it should be printed too. But this is only when using support anywhere - switching this off, it disappears...
    When thinking of an ooze shield I expected something like a wall around the object based on the projection, not a cocoon :smile:
    On the other hand it is clear that it is nearby the object to avoid oozing onto it.
    b.t.w. - how have you changed the spacing from 3 to 5mm ?
    I'm also trying to use an ooze for a single extruder print with my um2+. But cura seems to doesn't support it anymore. So is there any possibility?
    it is called 'draft shield' for a single extruder
    thanks a lot!
        • 9 replies
