Ultimaker Community of 3D Printing Experts
Makerfaire NYC 2014!!
  • Replies 137
  • Created
  • Last Reply
Top Posters In This Topic
Posted · Makerfaire NYC 2014!!
Great to see what happened - whish I've been there too... Next year maybe...
    Part four:
    2nd video by barnacules from MakerFaire with a lot of Ultimaker stuff.
    at 10:20 in the video, I noticed this UM2 is setup like the new UM2 I just got, in that the steel collar isn't tightened all the way down. This is apparent becasue the hot end is sticking out the bottom more, as well as there is not much of a gap between the teflon and steel collar.
    Is this the intended configuration? Are you not required to tighten the collar to the brass block all the way?
    The whole purpose of the collar/nut is to be able to adjust the nozzle height for if you have dual extrusion. Since that isn't working yet it shouldn't matter. But it does matter.
    The teflon isolator gets deformed easily and the "tighter" the collar, the tighter the spring above the isolator. So you want it very "loose" (it's still quite tight on the spring). But you want at least a tiny gap because if it's too loose then inside the nozzle - above the nozzle but below the isolator you can get a gap where plastic can leak into the gap. You don't want that.
    So it doesn't matter much but UM recommends 1mm gap. I go for maybe .5mm gap between collar/nut and isolator.
    I got a new nozzle from the spare parts store and noticed it "seems" thinner and longer than the one I have currently installed and the one you show on your picture. I'll see if its actually the case or not later tonight.
    That fan shroud hides most of the nozzle tip. It appears longer when you remove the fan shroud.
    Guess I'll go loosen my teflon isolators a little and see how they print. If all is well I'll keep them loose. The logic is sound in that lighter spring tension would ease the deformation of the teflon, I was just worried that retraction might start to fight the softer spring and cause problems...
    Nevermind that. They look pretty much the same
      • Startups, apply for the Forward AM Innovation Award!
        Are you a startup using 3D printing? Perhaps you should continue reading...
        Together with BASF we are launching the Forward AM Innovation Award - the very first global contest for startups developing new applications with 3D printing!
        Why apply?
        The winning startup will receive €100,000 in goods and services*, along with coaching and marketing exposure from top-notch leaders in the industry.
        Who can apply?
        Your startup creates products using Additive Manufacturing, is less than 5 years old, and has less than 50 employees. We are looking for 3D printing applications with a strong focus on innovation, sustainability and scalability.
        Dental aligners, shoes, tools, automotive parts, music instruments, industrial tooling and molding, medical implants, sports equipment, toys, architecture, fashion, construction... all are welcome to join!
        Do you have an innovative, sustainable and scalable idea that leverages the unique possibilities of 3D printing? Then it is time to apply!
        More information can be found here.
        Applications close on March 28th, 2021
        * What does "in goods and services" mean?
        The winner will be able to pick any item from the overall product and service portfolio of the sponsors, e.g. printers, materials, consulting, software... Choose whatever you need to accelerate your startup.
      • New here? Register your Ultimaker for free 3D printer onboarding course
