Nuts Fell Out - solved
jerry-blade
Posted · Nuts Fell Out - solved
When moving my Ultimaker Original from its build location to its permanent location, two bolts fell out as I lifted it. I have no idea where they came from, and inspecting the machine, I cannot for the life of me figure out where they fell out of. I am 99% sure they are not extra bolts as I was extremely careful to not have extra parts rattling inside the unit. I have done several test prints in that location so I am guessing the machine settled and these came loose and fell out. I am going to do another much more detailed inspection, but does anyone have a suggestion where these bolts may have come out from? I don't like the idea of my unit being short two bolts... that is, to me, a recipe for disaster down the road...
Otherwise, the unit is printing well...
Thanks!
-Jerry
    Like Gr5 said, it could be from everywhere! The thing is that bolts dropped out, no nuts. I'd say check the printhead where the thermosensor board is attached. There's bolts without nuts there(but with the nylon spacer units)
    Well in that case, have fun looking :) Really, it's impossible for anyone to guess which ones fell out, there's just too many possibilities (151 to be precise according to the BOM).
    Yeah I was just wondering if there were any likely candidates that seem to happen more often than others. Time to go through the machine with a magnifying glass... :)
    The nuts that drop out of my machine regularly are the XY slider block nuts.
    There, or the nuts on the end caps of the X/Y rods (8mm rods) which are a bitch to put back in. And I usually replace them with lock-nuts.
    Did they belong to the amplifier circuit board?
    Or maybe out of the Tslots in the frame and the bolt you used was maybe a little bit too small?
    or from the fan, look (or feel) at the inside at the 2 most right ones.
    Print one of these, it makes it soooo much easier: http://www.thingiverse.com/thing:44118
    I never managed to get it the right size so that it would fit....
    My printer wasn't doing so well when I printed that (a couple of years ago) so I just figured it was due to my printer. I fixed it by heating up a nut and pressing it into the cavity. Worked fine after that :)
    That is what I wanted to say.
    Titus should know.. that was one of Joris' tips at the previous Ulti-evening ;)
    I know Sander, I've tried, and still it hasn't worked yet, I burned my fingers instead :p
    This was the culprit - After inspecting them, I noticed several were loose... I am printing some replacement inside/outside endcaps... since replacing the nuts is going to be a royal PITA... having the nuts locked in on the inside caps, and having a way to calibrate the outside caps with a metal-on-metal point of contact (after rounding the bolts with a dremel) should reduce potential friction quite a bit.
    http://www.thingiverse.com/thing:99113
    http://www.thingiverse.com/thing:54075
    Thanks for giving me some places to look!
    -Jerry
    plus the half
    Printed one and used it (with the heated nut trick) - thanks!
