Hi 3DPoro, without hijacking this topic, what problems are you having? Send me a DM if you need any help.
About the print, before I went home yesterday I started a print.
Here are the results:
I was printed at 45mm/s, 200ºC and 80 micron, 5% infill.
Zero post processing, it was done this morning, picked it off the build plate and put it in front of my cell phone.
3poro 9
While I'm not actually in the mood of praising UM2 due to the problems I've been having, I'm pretty convinced the UM2 print is not made with FormFutura ABS. I have printed a lot with ABS, including FormFutura ABS. Regardless of temperature and speed, I just don't know how to reproduce the kind of surface stringing as I see on the photo. With PLA it happens easily, but with ABS - no.
Can you share the gcode file you used for printing?
