Judging extrusion temperature from the shinyness
joergen
Posted · Judging extrusion temperature from the shinyness
This post may relate to temperature problems within the Marlin 1.0.0 B1 firmware.
I started using the new Marlin, and so far it's great, other than the build in speed limit.
The picture above is printed/generated from a0.2mm profile in netfabb, printed at 225 deg, and max speed: 500% (300-500mm/sec?).
The first 35mm went perfect, the surface is really nice and shiny.
Then, suddenly at 35-44mm, the extrusion stalls, and looses it's shininess... the temp setting/reading is still the same (225), but the extrusion is forced, and gets a new surface:
a lot of fuzzy surface. Then between 44-52mm the extrusion becomes incomplete (no adherence, big holes etc), and the only way to bring it back is lowering the speed (back to 100%), from 52mm upwards. I tried increasing the speed back to 200%, but it also produced matte extrusion eventually.
Bernhard, let me know what additional info you need, if it is indeed FW related.
