calculation of E
alaris2
Posted · calculation of E
just checking my math here -
if I print a 10x10x5mm 100% solid fill object, with 2 perimeter lines,
would I not expect the volume of PLA extruded to be 500mm^3 ?
because Cura tells me I extruded 83mm of filament, at 2.85mm diameter and pi*(2.85/2)^2 * 83 = 529mm^3
so does that mean I'm overextruding, or do I not expect the numbers to match up?
If it does, presumably I can adjust E very slightly accordingly.. ?
    that's true I forgot about that 15% overlap. so doesn't that mean there should be even more material here than I expect - where did it all go then? when I measure the part it's 10.01x10.04x4.87mm?
    'product shrinkage' ??
        • 10 replies
