Already sorted it haha got two bits 4mm for £6 gbp
Also sorted the clips just need to fit all togeather and print
Will get some of that glue and give that a try aswell
I prefer elmer's wood glue mixed with water and painted on with paint brush but you can also use many other PVA based glues. For example any glue stick (used by students and teachers) works great and every UM2 is shipped with one. Keep it thin - you don't want much at all. Just spread it well.
Thanks. Whats the other manufacturer? I looked all over to try get info on this.
He might not be selling them any longer: http://www.ebay.com/itm/Heated-Bed-Kit-for-Ultimaker-Reprap-3d-Printers-MK2-PCB-Aluminium-plate-/161157442118?ssPageName=ADME:X:AAQ:US:1123
I think you will find the PLA sticks well to glass around that 60C temp (70C for me, maybe my sensor reads high) without any additional help like glue.
However, if it doesn't, I've found hairspray works almost too well and is less messy if you remove the glass and dust it with the hairspray OFF the printer.
You might want to consider Colorfabb XT in place of ABS. Seems like ABS really requires a heated chamber for all but the smallest prints. However, this is only what I have read as I haven't tried it yet (ABS).
XT is very ABS like although I suspect it is a little less brittle.
XT prints easily. However, on glass, I've found that hairspray is required to get the part to stick well. I was having some success without hairspray at 72C or a little higher but hairspray really sticks it to the point that you might not need a heated bed.
Heat bed and glass is working a treat just thort id update you all and let you no thanks
gr5 2,025
That's a designation of cost. Not weight.
