If you don't have a problem with the print such as under extrusion the print will be 100% solid ABS.
Just out of personal curiosity, why does the print have to be filled 100%?
Thanks for the reply - looks like I'll be ordering a UM2 then. :-P
I am going to use the ABS print as a master to make vulcanised rubber moulds from which I can cast pewter aircraft.
The ABS has to withstand the vulcanising process which requires high tempertures and pressures. Tests so far show that ABS prints with less than 100% filll disintegrate. The captive air expands and colapses the print during the vulcanising process. 100% solid PLA remains intact so I need something that prints 100% solid ABS ......UM2 :cool:
IRobertI 520
