Really nice tip with double brim and ribs! Thanks for sharing.
OK, here is another problem I'm having, not a big deal, but I'd like to know if it is a design thing ( as in, I'm the only one with this problem) or if it's a known Cura bug.
These 4 squares are built on the X,Y Plane.
When I load them into Cura, this is what I get... slice view, layer 1
The bottom does not touch the platform apparently, so I'm assuming it just moves on to the next layer.
SO, I cut off the bottom layer by .03mm and it seems to fix the issue.
No big deal, but I just ruined a print (AGAIN) becasue I forgot to check if the first layer was indeed printing. I usually always check my layer view before saving, but I forgot.
When it skips the first layer, is it also skipping the .2mm layer height for the first layer, and trying to print a .4mm layer with .2mm worth of filament on the 2nd layer?
Here are my settings
Just another thing to add to my "Watch Out For" list
Initial layer thickness must be set at least 0.01mm thicker than half of the layer height value otherwise Cura gonna skip the first layer (initial layer) completely.
If your layer high is for example 0.2mm then initial layer thickness must be at least 0.11mm
Layer high 0.25mm - initial layer thickness >0.13mm
Layer hight 0.1mm - initial layer thinckness >0.06mm
and so on ....
and so on ....
Awesome Info! Thanks for the share
DidierKlein 729
Clever the manual support (and the custom brim too)
Another quick Cura tip:
Picture this... you bring in a very small part. You multiply the part several times. Cura lays them out in a rectangular pattern
You get about 80% through the print, and pieces begin to get knocked over becasue the print head is skipping over parts and hitting the tops of the little pieces.
Here's a typical path the printer takes over a rectangular pattern of parts.
Not very optimal
Instead try to think outside the box... think circle
No more parts knocked over from the print head:)
Dim3nsioneer 557
Unless you have a dual extruder... :-|
But you could use the z hop feature anyway to avoid collisions...
I wish
Besides, I don't use the Z-Hop. I don't like the wear and tear on the brass nut from thousands and thousands of short jumps up and down...unless absolutely necessary. In this case, it's not necessary.
Also, I find that sometimes the Z-hop strings a little as it lifts and moves to the next piece, whereas no hop cleans itself off as it passes along the part to the next.
Anyways, that's just me
solid-print-3d 30
Just thought I'd share this technique with some of the new guys...
I designed this part to be printed in ABS. A crucial factor for a successful print was NO WARPING. The first print I let Cura throw in some brim. It started to warp about 20 or 30 layers in. Then I tried it again with a bag over the UM2, and a plexi panel to block the door. Started to warp at layer 60 or so.
Went back to the drawing board... redesigned part with my own brim. This time, 2 layers thick, opposed to Curas 1 layer, which breaks free from the glass pretty easy on large prints like this. I think I designed in a .22mm layer brim, and in conjunction with my .1mm initial layer height and .14mm print layer height, Cura rounded off to print 2 layers....Much stiffer, adheres to the bed better, and is still very easy to remove...if not easier.
Printed again... warped towards the end.
So I decided to add the ribs at the base, one on each corner, all the same length, and all .8mm wide, for 2 passes. I put the bag back on the top, covered the door and let her cook for 12 hours or so.
Success! And by success, I mean flat as the glass she was born on.
Here's an image of the model in Cura
And here it is printing
Here is an even more critical part, where the two halves mate together, there could be absolutely no warping, or functionality would fail.
here are the links in case your browser won't display the videos
Same methods of designing in a double brim, and ribs at corners really kept the part flat.
So, if you have a part that is similar and wont print flat, maybe these techniques will help you.
P.S. I am not a gun nut. I printed this as an advertising campaign. It is completely legal where I live to do so. Please do not go printing guns and saying Pat from SolidPrint said it was OK ... I am into archery however...PM me to see my 3D printed compound mini bows
