Posted · how to 'fix' a half finished print..
so 5.30 through my 6hr print the z stage hits a piece of scrap plastic I carelessly left at the bottom and jams...
I've seen a couple of people try to rescue prints, usually their print froze, so they knew where they were. but this kept printing several layers (which are of course all a mess)
I can count the number of erroneous layers - so I need to beg for a crash course in g-code now. is there some way I can ask the printer where it currently is in z?
I can then subtract n layers, find the relevant G1 ... Z in the gcode and snip everything before that point right?
are there any parts in the start gcode that I need to keep? I don't really want it to try and home the x,y,z obviously! and I think I need to reset the extruder so it doesn't try to extrude a stupid amount of filament - I forget the g-code for this :( but I think I need to keep the first 2 lines (M92.. and M109.. ) right?
thanks to anyone who helps!
my start g-code looks like -
;TYPE:CUSTOM
M92 E1075.04754031
M109 S210.0
G21 ;metric values
G90 ;absolute positioning
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G92 X0 Y0 Z0 E0 ;reset software position to front/left/z=0.0
G1 Z15.0 F400
G1 F75 E5
G1 E3.5
G1 X100.0 Y100.0 F3500
G1 Z0.0 F400
G90 ;set positioning to absolute
G21 ;set units to millimeters
M113 S1.0
M108 S25.0
;LAYER:0
M106 S255
;TYPE:SKIRT
