francfalco 37
Many thanks for the quick response! all understood.
Yep, i'll will move away from the default Cura profiles when i've had a chance to play with the settings.
And i think the chewed filament will be resolved once i get to 'know' the printer.
But that 3rd fan - is there no way to get it to power up and down only during the actual printing sequence - seems strange not to have it set up like that? - i suppose worst case scenario is just to turn the printer off when its finished printing, or i may just get used to the noise?
I'll also check out the trouble shooting guide
Cheers
gr5 1,872
Welcome!
I guess this:
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide
There have been issues with the filament getting ground up if you have lots of retractions on printers sold in the last month or so. It's very unclear what is going on. Spring too tight? Too loose? Different knurled sleeve? Here's some (unhelpful?) pics:
Marks made by 3 different UM2s - the pink left one is the one that grinds up filament. The other 2 can do 10,000 retractions on 8 meters of filament.
I don't get much (any?) dust.
Also I never used those quick print settings ever. I don't recommend them especially since you probably know most of the lingo and you can hover the mouse over anything you don't understand.
As far as the fans - the 3rd rear fan is always on. It comes on even before the lights. Is that what you meant? It was probably just quieter the first time you turned it on. Mine is so quiet I can't hear it more than 5 feet away but some of them are noisy. The side 2 fans should not come on when you power on - if they do the darlington is probably blown.
