Many thanks for your quick reply. I will be looking into Faberdashery.
As I am wanting to print products for a commercial purpose I originally considered the Mojo and uPrint SE machines. I was quite prepared to pay the higher capital cost. Fortunately I discovered that the on going material costs would be HUGE and much too expensive to make my project viable. A Stratasys agent provided some material usage costs on trial prints that I gave them. They were five times the cost of ABS filament on the Ultimaker 2. Since these machines can only use their own material from chipped metal containers it is such a rip off, just like regular ink printers.
I hope this will be my first of a number of Ultimaker printers - and with twin heads soon I hope.
Many thanks again.
IRobertI 502
Even though most manufacturers call the filaments "3mm" they are actually less than that, usually around the 2.85mm that Ultimaker sells. Check the fine print or ask the seller directly about the true diameter. Since you're in England I would recommend Faberdashery who make excellent filament (my personal favourite).
The Ultimaker can handle true 3mm filament, if you're lucky. But I wouldn't try it unless you absolutely have to for some reason. Filament that is truly 3mm is the exception rather than the rule so 99% of the time you don't have to worry.
One of the truly great things about Ultimaker is that they're open, you're never locked into a particular filament manufacturer.
