Unless I'm mistaken you could do G92 E1234 to tell the printer that this is what the extruder value should be without actually moving it. Do that at the start of each new pasted section. Should work I think.
Wau, this would indeed solve the problem I guess. Would save me lots of work! I will do a test with this, thank you very much.
"G92: Set Position
Example: G92 X10 E90
Allows programming of absolute zero point, by reseting the current position to the values specified. This would set the machine's X coordinate to 10, and the extrude coordinate to 90. No physical motion will occur.
A G92 without coordinates will reset all axes to zero."
IRobertI 516
