Black ABS Extrusion issues
addyyousef
Posted · Black ABS Extrusion issues
Hello,
I have problems extruding black ABS ONLY!!
I have 2 black ABS filaments and whenever I use them specifically it causes clogging and under extrusion. No problems with any other type/color of filament.
Anyone has a clue about this?
Thanks
    I had issues with some china ABS. the diameter was not constant and was causing a lot of friction in the bowden tube. If the filament get grind by the feeder you may have a similar problem. I have resolved my issue by changing to Orbi-tech ABS filament.
    What is the diameter of that filament? What temperature are you using?
    Thank you both for replying. I am using the Ultimaker Black ABS, and extruding at 260 c.
    I am also using black um abs. I print at 250. I had 1 clog when I switched from pla to abs. Cleaned the heater/nozzle and it was fine again.
    Thanks I guess it needed a little bit cleaning. I disassembled the head cleaned the burnt plastic. Worked fine again.
