Advise on Dremel accessories for polishing & abrading 3D printed objects?
Posted · Advise on Dremel accessories for polishing & abrading 3D printed objects?
I am looking for selecting the right Dremel accessories for:
  • Abrading
  • Polishing
Mainly with PLA and ABS printed objects.
If you have any experience, please advise me what accessories work best.
I have a Dremel 8200 set.
    PLA only. You need to be careful with a Dremel as it will generate heat. I have only used a Dremel once, with the paper based abrading insert on a surface that had support scarring. It certainly smoothed the surface (required) but the end result was not pretty (not a problem).
    I use one technique which gives excellent results. Typical reason would be to smooth off artefacts from corners. I use very high grade files, from the jewellery industry, and lightly, and I do mean lightly, file them off. This will depend on the filament but using black PLA as an example - the filing will remove the sheen from the plastic. I then apply with a rag some Baby oil over the area which makes it nice and shiny again.
    I was thinking of using a dremel on bronzefill, but it's not really working as well as hand polishing.
    The thumbler idea seems interesting though!
