Thank you so much for the quick reply Daid.
Now as far as PLA goes is there anything I should be aware of as far as the material goes? (IE, how it behaves at different thicknesses, or the usual do not drop, do not leave out in the car on a hot summer day)
I’d like to eventually do some items that have ball and socket armatures but unsure if I could pull it off without having a thick clumsy design.
Daid 304
Overhangs up to 60deg can be achieved. 45deg is a safe bet always, but more can be achieved.
Bridging is troublesome at 0.1mm layers, it still works, but comes out less pretty. For high quality prints I recommend avoiding bridging large gaps.
With thin parts you run into the "thin wall" problem. Which means it no longer puts in an infill while it should. Depending on what you are making, walls thinner then 1.6mm can be troublesome. However, if you use different settings this sometimes can work. For example, for these small gears:
http://daid.eu/~daid/IMG_20120520_230452.jpg
I used only 1 perimeter line of 0.4mm, instead of the normal 2 lines. Which made the infill better. However, this setting would not have worked in combination with overhangs.
I have no experience with ABS, but I've read that it's harder to print ABS at thin layers.
