DidierKlein 730
Great Stuff Daid :mrgreen: i looked at one model that had an ugly Z-scar in the front now it looks much better (in a gcode viewer) is there any way to see the z-scar in Cura?
Z scar is usually where you see small blue up lines.
Ok I found out what I did wrong, retraction was turned off which caused to extrude on places where it shouldn't ( at the z-line).
Daid 306
You are mistaken on this feature. It tries to hide the Z line in "inside" corners.
Simple example, on the following object, the Z scar was on the red line:
With the new code, it's on the green line, where it's as good as invisible.
