We're not makerbot. Your warranty is not voided if you put different material in it (at least, as far as I know it).
Or Zortrax, who also void warranty if you use anything other than their filament.
When using other then UM filament make sure it has 2.85 diameter! If it is not specified or the spec is only 3.0 then it is questionable if it works.
Warranty won't void. But if you have a problem which is clearly caused by the other filament, then that's at your own risk.
Blocked nozzle for example with 3th party wood fill or PVA, that's not covered under warranty. In general, just use common sense :-)
** Blocked nozzle for example with 3th party wood fill or PVA, that's not covered under warranty. **
Butt don't worry about that, if you read through this forum you will learn how to clean your nozzle ....
Australia has an excellent filament supplier called diamond age. They make fantastic filament. I recommend using them.
It's the other island (NZL)... But I agree with gr5: Diamond Age PLA is the best you can get IMHO. And shipment fees are reasonable from New Zealand to Australia I think.
I'd love to try some diamond age, but Printbl is always sold out of the stuff here in the states.
Printbl is not anymore reseller of Diamond Age. You have to order directly.
Does the same apply for the Ultimaker 3? Can the printer use non-UM materials?
Thank you!
Yes! Ultimaker is very open. This is the MAIN THING that distinguishes Ultimaker from closed source companies. This is the main reason why Ultimaker is so popular. You can mod your printer and not violate the warranty unless your modification caused it to break. Ultimaker was founded by 3 hackers and they think it's great that people hack their printers.
IRobertI 521
You are free to use whatever filaments you like.
