Dim3nsioneer 556
The problem is not completely unknown with this heated bed: http://umforum.ultimaker.com/index.php?/topic/6907-horizontal-banding-on-um2/
Things you may check:
- Does the z stage run up and down smoothly?
- Does the z nut have some significant play?
- Does the fan blow directly onto the nozzle?
- What do the walls look like when printed without fan?
- How stable is the nozzle temperature (some colors, including white, are more sensitive to the temperature).
- Compare the layers: do some show effects of under- or over-extrusion?
anon4321 16
Is the new platform rigid? Is the glass secure? Something is appears to be shifting during your print.
