I have a Printrbot and have 9 colours which have all printed perfectly.
But I bought brown and it jammed really hard.. The first thing I noticed is that it had an odd (rough) texture.. But then I got out the calipers and noticed that was as was as 1.90mm at parts, which is much fatter than the other filaments..
So my assumption is that it was the thickness which was jamming.
I dont' for a second thing that i can 'rip' of the excess.. But i am interested to try.. So i have ordered a 1.75mm drill bit.. And am going to drill some holes and then experiment with various "profiles" of the hole to see if I can get an edge, to 'scratch' off the excess material..
Luckily I have a workshop, and all the tools I need.. So I am going to make it my mission to make a 'rig' which can re-size the filament.. But I do accept that my chance of success is probably 10% at best.
But I guess, this setup will help me find the fat parts of the filament, and if I can't "rip" them, I could cut them out, and make a bunch of relatively short lengths which I could use for small projects.
Daid 304
You'll break the filament before you "rip off" the bad pieces.
1.90 does not has to be a problem, but it depends on your hotend and feeder. As this is 1.75mm, I assume you do not have an Ultimaker. So the normal Ultimaker solutions might not apply. What kind of machine do you have?
