Cura 14.10 RC6 and TweakAtZ problem
DidierKlein
Posted · Cura 14.10 RC6 and TweakAtZ problem
Hi all,
Just read on an other topic that someone had something similar to me.
I tried a print with TweakAtZ (used two times) on the latest Cura and this is what i got:
When i start the print, the bed is leveled up immediately and the print starts without heating.
I tried slicing a model again (did not print it) and this is the first difference i see i the gcode:
Without Tweak At Z:
;FLAVOR:UltiGCode
;TIME:7616
;MATERIAL:17606
;MATERIAL2:0
;Layer count: 288
With TweakAtZ:
;FLAVOR:UltiGCode
;TIME:<__TIME__>
;MATERIAL:<FILAMENT>
;MATERIAL2:<FILAMEN2>
;Layer count: 288
Could this be the problem?
    Yes. The UM2 looks at the "MATERIAL" lines to know which hotends (in case of dual-extrusion) to heatup. With no values there, the UM2 decides that it does not need to heatup anything.
