Cura plugin , no infill from layer hight
martin-schipper
Posted · Cura plugin , no infill from layer hight
is there ( i think not ) or is someone able to write a plugin
I would like to stop infill from a sertain layerhiight
im printing a covercap in flex fillement that has a center hang.
i whould like to support till the layer begins and continue without from there.
any sugestions
    Use SwatAtZ. Create a first gcode with no infill. Save it and then change your setting and add the swatAtZ plugin. Provide the fullpath to that gcode including .gcode extension and specify the height at witch you want the swap to occur.
    http://umforum.ultimaker.com/index.php?/topic/7290-new-plugin-swap-at-height/
    • 4 weeks later...
    Doing by hand might not work right at the transition because the E values (extruder position) are cumulative. So at the point where you swap one gcode might say move E to position 1.345 meters and the other to 2.771 meters and it will try to extrude a meter of filament. Or it might unextrude/reverse a meter of filament.
