Yes the pause at z plugin doesn't take in account the previously printed parts.
It's a limitation that would require some work to resolve but is not impossible.
It should only be considered, if it can be done easy. Either starting from the back or being able to define the printing sequence.
You can tell it where it should go in XY but cant tell the Z at the moment
ultiarjan 1,215
a negative could be that the 2th part would print over the string of plastic layed down before the start of the first part (between the pile of plastic of the innitial extrusion before printing & the first part).
