Multicolor print
blecheimer
  • 1 year later...
Posted (edited) · Multicolor print
This is probably a dumb question.
How do you guys ensure that the STL file you load into cura happens to be at the exact
coordinates, so there is no shift with the previous print ?
Thanks :>
    • 1 month later...
    Posted · Multicolor print
    @Melka
    I "found" out how it works with only 2 color. You need to center both .stl files (print one color and than the other color "who hold all together") and then you have the exact coordinates.IMG_20161130_193145.thumb.jpg.a6a3d861475129dfe8210fa956726e43.jpg I made this lettering by myselve.
    Today i want to try to print one easy file "just the G from the goole logo", with the 4 color + white (white hold all together), but i dont find out at the moment how it works. I will try it later/maybe next year ;) Sorry for my englisch...
    @backinblack81
    Wie hast du das mit 3 Farben gemacht? Schon einmal etwas selbst konstruiert und dieses Prinzip angewendet?t
