I think he'd like to adjust the fan speed during runtime.
I'm not sure, I'm lazy and spoiled due to the awesome Ulticontroller.
ooops. i meant fan.
when i use normal easy version of cura, the fan starts up automatically but when i go into normal version and setup every thing, and click print, the cooling fan does not start up.
a little mini question, why ?
Best wishes and thanks for a crazy good piece of software Daid !!
also mini mini request if its not there already ( second blond moment ;-) ) is there a measure tool in cura to see what exaxt size the model will be ? when printed ?
Thanks a million.
Ian
There is no model size measurement shown anywhere yet (bit silly, as I want it myself, and I already calculate it, just need to put it somewhere on the GUI)
The fan is enable on the 2nd layer when using normal mode. Simple mode incorrectly enables it on the first layer. Tests have shown that the first layer sticks better, and warps less if you do not enable the fan while printing that layer. If you want to change this layer number, it's in the expert settings under cooling.
Daid 305
The print temperature setting? First tab on the right ;-)
