Hi Dim3nsioneer,
Thanks for the reply, I can see how M200 could possibly work,
however I can't see an obvious method of setting M200 for each extruder independently, is it a case of just setting it in between the relevant T0 and T1 codes in the start.gcode accordingly? And if it is, will the value be remembered, or will it need to be included in the extruder change gcode?
Is it just a simple scaling of the E values?
I'll have a play tomorrow and see if I can get it to work...
Thanks again,
Rob
Dim3nsioneer 559
Hi Rob
Welcome to the forum.
I fear nothing has changed in Cura.
But there are two other possibilities in the meantime. If you have a not too old Marlin version on your UMO.
Possibility 1: Use the TweakAtZ 3.2 plugin with the extruder specific flow
Possibility 2: switch to volumetric reprap flavor and add two M200 commands to your start.gcode for setting the proper filament diameters
