It's a standard USB2.0 Type A to Type B cable.
Typically used for larger USB devices, such as printers or scanners. You can get one at any consumer electronics / multimedia store.
/edit:
There should be a cable included with the Ulticontroller kit. So you could (should) also report that to the Ultimaker Support and will probably get one from them.
Sorry, over-read that it's a used machine...
DidierKlein 730
You need a USB cable to update the firmware, how do you connect your raspberry Pi to the printer?
The Usb cable for the UMO is this one:
https://github.com/Ultimaker/UltimakerOriginal/blob/master/1144_USB_Cable/B1144-Z1P-A.PDF
you can probably buy it in any local store
