UM2 was just voted the best in the Make 3d printer shootout. So yeah! If you're in the market for an FDM printer it's a good bet.
You should decide first what your primary use for a 3D printer is. If you're making large props, phone cases and other things of that size, a UM2 is a good choice. It most likely won't be left behind for quite a while on those fronts.
If you're looking to make really small detailed objects like Jewlery or D&D figures, some of the newer SLA machines might be a better fit.
A lot of the development is happening in the material field and not so much on the printer themselves so you'll be able to benefit from those developments even if you get one now.
Might the Ultimaker 2 manage to print figures at moderate details of small size such as the D&D figures you described.
valcrow 144
