"Pause at Height" plugin causing layer to be skipped
jweaver
Posted · "Pause at Height" plugin causing layer to be skipped
I have just been playing with the "Pause At Height" plugin and have been looking at the Layer view.. And noticed that there is apparently a missing layer when the plugin kicks in.....
On the layer in question, you can see tool path lines (blue) but nothing extruded..
Is this correct? Is this simply a GUI thing? Or is CURA really skipping a layer (I have tested thsi with 14.09 and 14.10_RC7).
NB.. To show this, I have simply chosen thick layers to exaggerate this.. But the same effect is seen irrespective of the layer height.
