It was mostly useless and the feature was removed. Although many complained - the small minority who used it were quite vocal. This feature exists in a few other slicers.
What it does is make 2 passes on the outermost skin at 2 different heights. So for example if you sliced .2mm and enabled "skin" then it would do all the inside (including most of the shell) at .2mm and then do 2 passes around the outside .1mm thick each. But they were *identical* paths so you didn't gain any resolution - just made the "horizontal layer" lines harder to see.
gr5 1,968
