mmm not sure about that ?
i have a model which is 70 meters long, i just saved it as a STL, no tweaking. brought it into Cura and it is tiny.
I did no conversion, saved out my 3d model as 1to1 in METERS.
Because I cant find a measuring tool in Cura, I cant measure the object and try and find out what scale conversion is going on ?
Here is a photo to illustrate the problem.
Thanks.
Ian
Daid 301
There should be no extra scaling except for the scale factor you give in. 1 "unit" in the model should come out as 1 mm.
