do we use
"pip install power"
because its asking for sudo to run the inter connected dependencies
do we use
"pip install power"
The version of 'Power' you are using is most probably not compatible with the rest.
Have a look at http://umforum.ultimaker.com/index.php?/topic/7577-cura-mac-os-x-sources-compil/, it might help you in getting all things working together on a Mac.
do we use
"pip install power"
pip has a different power module then the one Cura is using.
Daid 304
Power is pulled from:
https://github.com/GreatFruitOmsk/Power
