Yes, very familiar. It's backlash. Make sure the short belts are TIGHT. The long belts shouldn't be too tight but reasonably tightened. If you really want to get rid of the backlash on your UMO, I recommend switching to direct drive and replacing pulleys and belts with GT2 belts. With those two changes I got the backlash on my UMO down to about 0.05mm.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Dim3nsioneer 557
