If you can push filament through without any issue (that is, you can straighten a piece of filament, head the nozzle, and push it through with no major issues like burning or smoking), I wouldn't expect the problem to be at the hot end--it could be either in the Bowden tube itself (ie check the ends of the tube for any potential blockages and if you feel the need run a little Teflon through it to reduce friction) or the feeder.
I had issues with regular skipping; it turned out that I just needed to really increase the tension on my feeder. I don't know why it was so low when mine came in, but it was a pretty effective fix. Worth a shot if you know what you're getting into.
eric-lester 1
