It is possible to flash a firmware were 0.0 is in the middle (there is still homing involved I would guess). But if you print head bumps in the corners it is better to make a modification to the endswitches so you can home again. Otherwise you have to position it in the middle and how would you know if that is correct. If you want to print something covering the build plate you would like it to stop on the edge and not bump into it.
Glue something on the end blocks or print some adapter so you reach the end switch.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
zoev89 73
