Heated Fan vs Heated Bed
Posted · Heated Fan vs Heated Bed
I was wondering if it is possible and many even easier to use a 'heated' fan rather than a heated bed?
Does anybody have any experience with it or some arguments why it may or may not work :).
    I don't think it will work, because the idea behind the heated bed is that you keep the bottom warm enough to stick to the bed. (as warm plastic gets sticky)
    I've seen some experimenting with a "heated chamber" by moving the steppers on the outside the Ultimaker, and enclosing the build space. That would still require a heated build surface, but this setup can prevent some cracks in ABS models as they cool off.
    J
    Also, you want your plastic to cool and become solid before the next layer.
    I wrote a program to output G-code yesterday and forgot to put in an "enable fan". So my build started, and things got sloppy after a few layers. Apparently things heat up/don't cool enough that it isn't solid enough for the next layer.
    And I had already put it "too" slow. I put in 30mm/sec for the first layer and then forgot to change speeds. So it rpinted the whole thing at 30mm/s instead of faster for the higher layers. A similar object printed just fine at a higher speed, but with the fan on.
    Anyway of course I put in the "enable fan" but forgot about the speed and it printed great in twice as long as the other (similar) object.
        • 9 replies
