Problem with Spiralize the outer contour.
jangermann
Posted · Problem with Spiralize the outer contour.
This is my first vase attempt with Cura, and I am not happy :sad:
When printing, the extruder stops for a very short time, every round of the vase, this leaves a small dot.
It leaves a spiralize path of dots on the print.
Is this a Cura 14.09 bug??
Trying to print this model (it is solid and should be OK)
Se the problem here:
Why oh why?
    Looking at the rebuilt version it in layer view you will see the toolpath switching from inner to outer shell. That vase is too thick to be printed in one pass with spiralize.
    The solid version seems a better fit.
    Thanks for your answers.
    I will try V14.12 to night and post the result.
    I did one last night but with 14.07 and it was fine.
    I can now confirm that V14.12 is fine.
    Then this is most likely the result of the path order bug in 14.09, which is fixed in 14.12
