Need to split an object into 2 part and save the gcode .
protoverse
Posted · Need to split an object into 2 part and save the gcode .
Hi All . .
I need to print a product .
the product i'm trying to print is this: http://www.thingiverse.com/thing:437382
So i thought of printing the top layer separately and stick it to the rest of the product because the the top ring is getting messed up due to support issues .
I tried to use the cura layer view and tried to stop it at the required height and saved the gcode but this is not working and the entire objects gcode is getting saved .
can someone please help me out with this . .
the pics of the current prints can be seen here . . http://imgur.com/a/bBhnc
    Mmm ... both links do not seem to work ...
    Anyway .. NetFabb free edition can easily split an object in many parts (just few clicks) and you can save each part as .stl to next produce separated GCode ...
    Guglielmo
    EDIT: Look THIS thread for "how to do" ... ;)
    if this is the object your printing:
    i think splitting the print might be a bit overkill. and getting it back together in one piece might be more trouble than worth. have you tried printing with support enabled? since it is horizontally symmetrical, you'll need to select everywhere. might not be the best looking on the inside, but with a little cleanup ...
    That is the object i'm trying to print . I have used support structure but i'm not getting the finishing that is required . Sorry about the image links earlier , the correct one can be found here : http://imgur.com/a/bBhnc?gallery . DO you think i can use a hot knife to smoothen out the ring ?
    I shall also try to do it with netfabb once . .
    http://www.thingiver...om/thing:437382
    Do you think i can use a hot knife to smoothen the rings ?
    It shouldn't be that hard to glue back together i think.
    You can also do this easily in Cura:
    Go to advanced tab and cut off object bottom to where you want to split. Save to gcode
    Then rotate the object 180° and cut object bottom to have the second part. Save to gcode and print both.
    Or cut off object in the middle and duplicate the object (just rotate one 180°) and print both
    WOW ... thanks Didier ... I have always ignored this :D:D:D
    Guglielmo
        • 4 replies
