problems with curaengine
saga
Posted · problems with curaengine
Hello,everyone. I am a newbie to curaengine. I taped the this to the command line:
curatest -v -o d://test.gcode d://test.stl
and here are the results:
Default config 'default.cfg' not used
Loading d://test.stl from disk...
Loaded from disk in 0.031s
Analyzing and optimizing model...
Face counts: 900 -> 900 100.0%
Vertex counts: 2700 -> 440 16.3%
Size: 50.800000 47.938000 3.175000
vMin: 77.100000 78.531000 0.000000
vMax: 127.900000 126.469000 3.175000
vMin: -25.400000 -23.969000 0.000000
vMax: 25.400000 23.969000 3.175000
Matrix: 1.000000 0.000000 0.000000
Matrix: 0.000000 1.000000 0.000000
Matrix: 0.000000 0.000000 1.000000
Optimize model 0.016s
Slicing model...
Layer count: 30
Sliced model in 0.016s
Generating support map...
Generating layer parts...
Generated layer parts in 0.015s
Generated inset in 0.016s
Generated up/down skin in 0.109s
Wrote layers in 0.00s.
Total time elapsed 0.20s.
Print time: 0
Filament: 0
Filament2: 0
Obviously the layerthickness can be read, but why it shows that default config not used? And the gcode I got is not complete either.
;Generated with Cura_SteamEngine DEV
M109 S210 ;Heatup to 210C
G21 ;metric values
G90 ;absolute positioning
G28 ;Home
G1 Z15.0 F300 ;move the platform down 15mm
G1 F200 E5 ;extrude 5mm of feed stock
;Layer count: 30
;LAYER:0
M127 T0
G0 F9000 X70.800 Y72.231 Z0.300
;LAYER:1
M126 T0 ; value = 127
;LAYER:2
M126 T0 ; value = 255
;LAYER:3
;LAYER:4
;LAYER:5
;LAYER:6
;LAYER:7
;LAYER:8
;LAYER:9
;LAYER:10
;LAYER:11
;LAYER:12
;LAYER:13
;LAYER:14
;LAYER:15
;LAYER:16
;LAYER:17
;LAYER:18
;LAYER:19
;LAYER:20
;LAYER:21
;LAYER:22
;LAYER:23
;LAYER:24
;LAYER:25
;LAYER:26
;LAYER:27
;LAYER:28
;LAYER:29
M127 T0
G1 F2700 E-4.50000
G0 F9000 X70.800 Y72.231 Z8.175
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
I pondered the error must be the readsettings function in setting.cpp, which is a paradox due to the layerthickness item. Can anyone tell me where I went wrong and how to write my own config files?
Thank you very muck.
