You can change the machine settings to indicate a larger print bed, or you could just use Kisslicer...
make sure you don't have a skirt configured in expert settings. Set line count to 0.
I ran in that situation some time ago where I needed to fit a large piece that would need to space above the glass locks but at a height where it cannot collide with it.
I changed the code in cura to remove the 4 gray zones from the platform in the Machine Settings (glass lock). This allow you to use the full space. If you think the print head will collide with the glass locks you can open them and use something else to hold the glass in place like tape.
Here is my change:
https://github.com/pmsimard/Cura/commit/f7d7f3caf09a6f39e7340d0cf45434684835c360
If you want to just remove the gray zones on the platform just comment out the section in profile.py where there is a comment #UM2 no-go zones
lol I just looked at those images again... What a dirty print...
haha PM, i`m sure it looked great when you cleaned it up
A single colission with the glass clips can ruin your nozzle. Stupidly enough we only discoved the problem when we started shipping the um2 (did I mention that the release of the um2 was a overtime nightmare? ). So thats why we hacked the disallowed grey zones in Cura. It's not a good solution, but it's there for a very good reason.
Maybe cura could know that past a given height it can go over it.
Yep I had a collision like this using the pause at z plugin and it hits pretty hard.
tinkergnome 926
Maybe there is a correlation to the configured "Printer head size" in the machine settings....?
Perhaps you can tweak these a bit?
How much space is left between the print head (fan shroud) and the walls while printing the outer lines?
Sorry - only more questions - no solutions...
