Dim3nsioneer 528
Let me guess: It's an UMO. Recently, I saw something similar on an UMO with very loose belts. It might be tremendous backlash and the printer is doing more or less two adjacent lines on top of each other. Just tighten the belts and it should improve in this case...
Nicolinux 287
This looks very weird indeed. Can you post your print settings. Did you set the nozzle size correctly? And which printer are you using? Ultimaker Original or Ultimaker 2?
