I can not drag and drop my .stl files from the explorer to Cura in 15.1 RC7. It just displays the forbidden sign. Loading via load button works however.
Frederik, this is most likely because when you install things, you need to have elevated/admin permissions and the installer is started under an admin account. When installers like the one Cura uses offer to launch Cura at the end, it too is run with elevated/admin privileges under the admin account.
Win7 won't let you drag/drop from a non-elevated process (Windows Explorer) to the elevated copy of Cura started by the installer or from one program under one user to a program running under a different user.
Simply restarting Cura gets it running under normal permissions so Drag/Drop works.
Labern 774
I have been trying out the new Quick Print profiles and they are greatly improved with no problems so far.
