Sign in to follow this
ultiarjan
Big & Little news !
Posted · Big & Little news !
Nice machines. :-P
But: Are the names another example of names given at R&D and just picked up by marketing? (I now see why the R&D people started using ugly names like pluggable Unicorn... ;) ).
Is it just the picture or does the UM2 GO have an unnecessarily small print bed? Where has the famous build-space-to-machine-size-ratio gone?
Share this post
I wonder how the site will look like tomorrow :)
And also the forums I guess.
Share this post
Uhm. No. They where called the Goliath and Calimero during development. (And Mini and Maxi)
And is it just the picture or does the UM2 GO have an unnecessarily small print bed? Where has the famous build-space-to-machine-size-ration gone?
That was quick, told them someone would notice this. But didn't expect it from the press photos. Kudos!
The print volume is 122x122x110. But the head movement actually has ~10 more mm in the X direction on both sides. So with some hacking you could get 140x122x110 out of it.
The external size could not be made smaller due to the electronics size, else we would have made it to fit the build volume.
It does look super cute in real life. (But it's bigger then the TITAN :p )
Share this post
Nice machines. :-P
But: Is it just the picture or does the UM2 GO have an unnecessarily small print bed? Where has the famous build-space-to-machine-size-ration gone?
I think it's logical that the ratio get's (a lot) worse on a small machine as the space needed for the printhead stays the same.
Share this post
The ratio *could* have been bigger, but we couldnt get the machine smaller due to the electronics.
Share this post
Am I correct that the Z-axes are the same diameter on the "extended" (this name is to long IMHO...) as on the normal UM2 ? So if I would "extend" my UM2 would I only need ?
- new side panels
- 2 Z axes
- Zstepper/leadscrew
optional, longer stepper covers
Share this post
- new side panels
- 2 Z axes
And longer electronic cables.
Share this post
Ah yes, thought about moving the electronics to the back, but that's probably not an option looking at the controller in the front plate..
Share this post
I like the mini one. will check out the specs when they get around to updating the website.
I have never needed a taller printer than my UM2 but wider would have been nice.
Share this post
I expect the UM pico to perform even better then the UM2, as it has even less resonance during printing, and print with greater speed.
But does the UM grande really have the same z-axis rods as the UM2 ?, when I made my UM taller, I immediately noticed big difference in z-axis wobble with the too thin rods.
and can we expect the new Cura when the new UM's start shipping ? (deadline Daid ?)
Share this post
and pricing based on ZDnet .. extrapolated to euro
3xpricing
edit: according to the UM website the europe pricing is 1195 euro for the GO and 2495 euro for the extended (ex VAT), so the new ones are relatively more expensive in europe....
Share this post
It's only 100mm. We didn't notice any "bad" effects that we noticed with the really tall ones that we prototyped a long time ago. The UM2 bed also helps a bit on this aspect, as well as the lighter head.
Planning to have an update on Cura out before that, just to assist everyone that already has one of these machines for testing and showing off (resellers get them sooner for promotion)
Share this post
The website doesn't seem to have many specs on the new UM'S. Do they have upgraded feeders or nozzles?
Will the UM2go be upgradable to dual extrusion?
Is the spool holder the same as um2?
Share this post
First half of the first question is the most interesting IMHO. ;)
Share this post
I was very excited about the Go when I saw the promo, but now the prices are known, my excitement has waned. For the same money as a single go, you could buy 3 Robo Rminis, also to be announced at CES, with almost the same build size (4.5 inches cubed), It's a very competitive market out there and those wanting to do affordable printing will be going to other manufacturers. Don't really want to see Ultimaker become the Apple of 3D printing.
Share this post
I found it interesting to see that the shop now has U-PET material.. no further info though..
also U-PET is now the default material you get for free when buying a new printer..
Share this post
This material was mentioned before here in the forum: http://umforum.ultimaker.com/index.php?/topic/8237-pla-hitzebest%C3%A4ndiger-machen/&do=findComment&comment=81712
It seems that sometimes the language specific sub forums get the information first; it's quite similar on the French sub forum I think...
Share this post
No new feeders or hotends. Yes, we are working on that, it was not ready for these machines. The latest teflon pieces are a bit better. But other then that, you can expect sort of the same problems with these as with the UM2. After all, they are variations of the UM2 as the names imply.
We decided quite a while ago that we are not going to join the "race to the bottom". Yes, there are cheaper options out there. Quite a few actually (I would recommend the printrbot options over the Robo options if you want cheap).
But we prefer to have highest quality prints. And better user experience. (Also, for 400 euros, you cannot build an Ultimaker. Unless you have it assembled by child labor)
U-PET
Yes, this was a bit unannounced and added to the shop. It's one of those things where it shows that we are doing way too much at the same time. It's U-PET. It's great. It's printable PET, in multiple colors.
It has been tested a lot and prints great in the UMO and UM2. The latest UM2 firmware has material settings for this as well.
Share this post
can't find any specs on U-PET on the UM shop, whats typical the printing temperature of this stuff ? how does it compare to colorfabb XT ?
Share this post
How much does the small one weigh?
I can see using it for demos but if I'm traveling with it, size AND weight are both important. I don't work out and have poor upper body strength.
Share this post
Not sure on the weight, it's lighter then an original that's as much as I know on that.
But I do know it comes in special packaging that is designed to be re-usable and easy for transport.
I think the XT is also a form of PET (could be wrong here).
Settings for the UM2 are:
Print temperature 250C
Bed temperature 60
Fan speed 50%
Share this post
Bed temperature 60
Fan speed 50%
What's the corresponding print speed? 50mm/s? With colored XT these are more or less the parameters I can print with 25mm/s.
Can you say anything about interlayer adhesion?
Share this post
I don't really get why you would want a smaller one. IMO the Original with the printed handle is portable enough. I take it by bike and train to the ultievenings :p
But I'm curious to see it IRL, it is said to be really cute!
Share this post
You could have said about the same for these devices: ;)
Share this post
    • Survey: Understanding your workflow
      Interact with future concepts and aim to collect your feedback and opinion. In particular, if this would/could be a welcome addition to your 3D printing workflow. Interested?
    • Coronavirus: Let's do our part
      Through this post I would like to further explain what we are doing, and what you could be doing.
      Our efforts consist of 2 layers. First; connect medical institutions and hospitals to (local) 3D Printing hubs to help them print parts of which a 3D model already exists. And second, contribute to design the necessary part and then have it printed via a (local) 3D printing hub. Experts are available from within Ultimaker and from within our network of 3D printing experts.
      • 45 replies
Important Information
Welcome to the Ultimaker Community of 3D printing experts. Visit the following links to read more about our Terms of Use or our Privacy Policy. Thank you!
