Daid,
I set my note out before I read the other threads, and some of the other suggestions to trouble shoot this particular anomaly.
I did not do any of it until after I had tested with RepG v 25 Beta Skeinforge 35 Ultimaker Advised 5D v1.0 firmware and the failsafe slicing option for the ultimaker. I did print repeatedly without error. I printed with Mac OSX SL and Windows 7. I have a Ubuntu setup but did not test that.
Testing went like this:
Cura 4 Mac OSX == Problem
RepG 25 Win7 == Working
Cura 4 Win7 == Problem
RepG 25 OSX == working
Cura 4 Max OSX == Problem
RepG 25 Mac OSX == Working
For Cura Testing I use the complete package that came with v4, Slicing with Cura and Printing with PrintRun. Firmware loaded with the Cura Update Tool
For RepG 25 Testing I use RepG to slice and build/print. Firmware Loaded out of RepG
What I did not test was Cura2 or Cura3. I will try that tomorrow. From the information that was in the other posts, I do have the Blue LED and the electrical tests seem to be as you have stated. Again, I did not make any changes to the wiring or inspect it before my tests. I will get everthing back together in the morning and test again with Cura2, Cura3, RepG 25 and Cura4. I am going to confine the test to Mac OSX. This just takes a lot of time and the results for me have been identical between Mac OSX and Win7.
If there is something spacific you want me to look at or try, please do not hesitate to ask.
BTW, I am quite capable of flying my Ultimaker into the ground from my keyboard. If there is something I am doing "dumb" please do not hesitate to poke me in the bad eye.......
Regards,
A
Daid 304
An MAXTEMP or MINTEMP error indicate a problem with your temperature sensor, you need to check if all wires are properly connected. Especially the red/yellow wire, if they are screwed in tightly.
It's something the firmware checks, not Cura.
