Cura Printing Time
raymond91
Posted · Cura Printing Time
Hello Everyone,
I am a new user of CURA Software.
Regarding the printing time, does anybody knows how the Cura software calculate it?
I try to look at the programming code, but couldn´t find on how they calculate the time.
So, does anyone know the algorithm or the formula to calculate the printing time?
Thank you very much in advance
    Hi Raymond,
    Welcome to the forum,
    The print time is calculated in CuraEngine. CuraEngine is the c++ slice engine used with Cura.
    Try looking for when its writing "Print time:" result and track it backward in the code.
    Hello Everyone,
    I can only give you the same info as I already gave you trough the support staff.
    It's calculated with that code. That's the algorithm. It's a complex whole where that code calculates exactly what the firmware will do any how much time that will take.
    https://github.com/Ultimaker/CuraEngine/blob/master/src/timeEstimate.cpp
    and also how to calculate the travel distance of the extruder?
    I´m able to calculate the extruder travelling distance in a 3D model Cube.
    however, if the model is too complex...., then I have no idea anymore.
