If the X and Y motors can do 250 mm/sec, why can't the Z-motor?
The answer is that the Z-motor has a different "transmission chain". For a revolution of the X motor, the extrusion head moves 10 teeth at 2.5mm per tooth or 25mm.
The Z axis is different. For a full revolution of the motor, the platform moves down one thread on the big driveshaft. I haven't measured it, but it's about 2 or 3mm.
But if the X motor can do 250 mm/s, it will be doing 10 revolutions per second. So why can't the Z-motor do 10 revs/sec? That would come to 20-30 mm/sec for the Z axis. That would be useful to reduce the blobs tenfold... :-)
I can understand that when it has to push the platform up it can't achieve such high speeds. So I'd be happy having it limited to 5mm/sec in the Z- direction, but a limit of 30 in the Z+ might be useful....
Daid 303
The firmware limits this to 5mm/s.
It can reduce the Z scar a bit, but it's not that important as a setting. However, some machines are experiencing missed steps at the Z at some speeds, so then it's important to lower it.
